New to me X304, oil everywhere!
IF you are going to remove the tins then it is an engine pull. As none of the screws are easily accessible as everything in the following image plus the flywheel has come off. Item 6 highlighted are the tins screws. And there is also #16 screws and the fuel pump bracket [#15] that might need to come off.
Even the Briggs Slomo showed that engine has to come off to get to the third screw.
I don't if you can access the following JDParts website but this is your mower.
https://partscatalog.deere.com/jdrc/navigation/equipment/26852
I grabbed a picture of "a' tin off Google. Not the exact one for your engine. Just to show what they look like.
On top of the crankcase above the carb between the cylinders. A plate with 4 screws.
Yes, number 6 are the bolts I was talking about at the rear of the engine. You could bend the tab back and then get a wrench in there, but then your tin is ruined. If this helps to find out what's leaking, I have no problem with pullinh
Thank you to everyone who replied. I'm finally able to post the pics of the engine, after having the computer fixed. If you can see where the oil is leaking from, or other problems, please let me know. Thanks in advance.
