Mattmotors
- Oct 10, 2011
- 88
Hi All.... Model: Husqvarva YTH24V48 SerialNumber: 012315A046880 Proudct: 960450046
My front wheels have a lot of play in them so I am looking to replace the plastic bushings with flange bearings. I took off a wheel to measure And I found the following:
Spindle: 3/4 inch Bushing OD 1 inch. Hole ID in rim 1 Inch. Being plastic, the bearings probably wore out after the first season thus the wobble in the wheels. I am looking to replace them with flanged ball bearings but every kit I can find says the OD of the bearings is 1 3/8. (Amazon). Some of the kits have pictures showing the OD measurement as 1 3/8 . Too big for the hole in my rim. Are they measuring the OD of the bearing or the flange? I got the part number from Parts Tree which shows the plastic bushing as part number 532124959 superseded to 532009040. When I search the part numbers on Amazon all these bearing kits come up showing the bearing size as 1 3/8. Can someone shed some light on this for me? Thanks, Matt.
Side note on the Husqvarna, Neighbor gave it to me with a rod thru the crank case (Briggs). Neighbor next door gave me a Cub Cadet with blown head gaskets and magnets off the fly Wheel stuck to the stator. (Kohler). simple swap. It was a good winter project. Even came with a bagger.
