Craftsman Garage
- May 2, 2021
- Threads
- 45
- 573
I've got a Kohler KT735 V-Twin engine here, and it just keeps flooding. The first and only planned repair was to replace the head gasket, it had blown and I always wondered what that hissing sound was when it was cranking before I found it. It was blowing to the outside, if that matters. Anyway, after I replaced that and assembled everything, the electric fuel pump system kept flooding the carburetor. I sorta expected that, since it is electric instead of vacuum but it had worked for months before this repair. I converted it back to a vacuum system, just to eliminate that as a possible issue, and it is STILL flooding. I will crank it and crank it and no starting, but only when I turn the key to off will it flood the carburetor and intake with fuel. The fuel pump works, and it floods like this with both a aftermarket as well as a OEM carb. The fuel solenoid DOES work and you can hear it click with the key at RUN. Any ideas why this could be happening? This is on a 2014 Craftsman T7400, by the way. Thanks guys.
