The Brain
- Jun 26, 2019
- 77
I'll take a good image of head. it felt smooth around the carbon stain. I don't have a tempered glass table. I do have a piece of plexie glass about 1/8" thick x 2'. what do you think about the amazon gasket?Need a better picture of the head.
You can carefully get the left-over material off the head with a razor blade.
After that you need to resurface the gasket face of the head using a true flat surface like a tempered glass table and 400 grit wet/dry sandpaper. Scrub the head gently across the sandpaper and you might be surprised how much sanding will be needed to re-true the gasket surface.
Sand until the entire gasket surface is clean aluminum.
The block surface will also need some light cleaning.
