Spark plug gets gas fouled every cold start
The Brain
Need a better picture of the head.
You can carefully get the left-over material off the head with a razor blade.
After that you need to resurface the gasket face of the head using a true flat surface like a tempered glass table and 400 grit wet/dry sandpaper. Scrub the head gently across the sandpaper and you might be surprised how much sanding will be needed to re-true the gasket surface.
Sand until the entire gasket surface is clean aluminum.
The block surface will also need some light cleaning.
I'll take a good image of head. it felt smooth around the carbon stain. I don't have a tempered glass table. I do have a piece of plexie glass about 1/8" thick x 2'. what do you think about the amazon gasket?
MParr
not sure about the fuel pump, don't even know where it's located. when I turned the ign. key the fuel shoot up over ten feet.then when dissassembling the head seamed like the whole cylinder was filled w/ fuel.
It certainly sounds like you have an electric fuel pump mounted on your engine. A standard pulse fuel pump will not pump fuel unless the engine is turning over. Follow your fuel line from the carburetor. A pulse fuel pump will look like this. 👇
Tiger Small Engine
It is a Nikki carburetor from the looks of pictures. If you can’t tell a pulse fuel pump from an electronic fuel pump, I would suggest going to a shop for help. Why would an electronic fuel pump be on a carbureted engine?!
MParr
We aren't getting all of the details.
Fuel delivery and fuel metering seems to be the main problems. An electric fuel pump will definitely flood out the engine and carburetor. Fuel is bypassing the needle and seat. There could be a problem with the float too.
Looking at the overall setup of the Rear Engine Snapper, the fuel tank height is above the carburetor height. If that is how it actually setup, there is no need for a fuel pump. Gravity feed is all that's needed. That takes us back to the carburetor.
The Brain
Here’s the cylinder head after blown head gasket. not seeing metal damage image
I had to use the parts engine head from orginal head.
Replacement engines head damaged under rocker arm mount. I assume it’s trashed image
Aditionaly I do smell a bit of fuel in the oil. Thanks for advising.
edit as far as the fuel pump goe's I previously mentioned I don't even know where it's located. I belive MParr is correct about the gravity feed fuel.
I did turn the key switch to ignition turning engine over this is when I observed the fuel shooting straight up real high.
The Brain
do you have a part# for this carb. thanks
MParr
Is this your correct engine number?
219907-0131-B1 - Briggs & Stratton?
If not, please list the model number and serial number.
The Brain
yes that is the correct engine# as ingraved on the valve cover.
The Brain
the amazon gasket appears to be the correct gasket however the bot is confused as usalesnapper gasket bot is confussed.jpg.
MParr
I believe that this is your carburetor. Some of the others on here can confirm.
@ILENGINE
@Auto Doc's
