Timecutter Valve Adjustment
MParr
Again, you can buy gaskets for the Kohler tin valve covers.
There is also a retro valve cover kit available. The kit includes new composite valve covers with o-ring style gaskets.
I like the Right Stuff by Permatex this also what Kohler recommends
Good product. I despise it for the next guy chipping away trying to remove it.
Auto Doc's
If it's a Kohler engine then it has hydraulic lifters and no valve adjustment is needed.
Hello R.,
Kohler command has hydraulic lifters.
Kohler courage has adjustable rockers.
GasSniffer
Mine is a 7000 series with the black valve covers. Mine doesn't have heat shields either.
Better than trying to remove Hondabond 4 that is grey at installation but will turn burnt black and crack and start leaking on the 7000 series valve covers within 30 minutes of first start.
