countryboy36266
- Sep 25, 2025
- 3
i bough this mower at a swap meet did not run i rebuild the motor the deck flush the hydraulic system put all new oem belt on it and cut my yard with over time the drive belt act like it slipping and if you keep running it the belt burn off i have change 8 time and i can't find the problem this mower has a hydraulic pump and two motors i need help
