Reverse implement operation, let's you back up with blades engaged
Plug and play, new engine harness had a green wire the old one didn't have ,Did you have to do any modifications to plugs or wiring or was it plug n play?
Just what I was unable to find. LolDo you mean something like this?
Yes reverse works fine, replaced drive belt when I did engine replacementReverse In Operation?
