kawasaki FR691v smoking
ACF
have a kawasaki fr691v-bs29 that smokes light gray/blue smoke looks like a smokestack while running. did compression test each cylinder was 130 psi. did leak down on both cylinders had air coming out muffler. so do i have bad rings and bad valve on discharge side. was thinking value guides maybe but not sure to how to check them. any suggestion would be great help
thanks AC
Were all the valves closed when you did the leak down? All must be closed (TDC).
Continual smoking is piston rings/bore slash sealing.
Auto Doc's
Hello ACF,
How many hours are on this engine? Any maintenance history?
Having 130 PSI compression does not support failed rings, but they can stick the oil control rings. Change the oil and add a 1/2 cup of Marvel Mystery oil in with the new oil and that will unstick the oil control rings after a few hours of running.
As for your leak down test, it is best to remove the valve covers and verify both rockers on each head are loose fitted, and the piston is held at top dead center in the cylinder. Better yet, back the rockers off and remove the pushrods to get the best results to verify if there is actually a leak down past the valves. A little air from the dip stick tube is normal, but a lot is not good.
If you happen do the heads, lap in the valves to ensure proper sealing and replace the valve seals.
ACF
engine has 135 hours, removed valve covers to verify tdc, got nothing from dip stick just muffler
135 hours and was tdc had valve covers removed watched springs
Check valve lash per your engine manual.
txmowman
Pull the rubber tube for the air filter off from the intake pipe (before the carburetor). If you live in the south, the engine is possibly dirt ingested due to inadequate air filter maintenance. Sorry to say but I see a lot of it. Valve guides are not the issue.
ACF
Hello ACF,
changed oil and added marvel mystery oil ran for over 2 hours was worried at beginning but after over 2 hours no smoke, do get a little puff when throttle increased, now would you adjust the valves
Auto Doc's
Hello ACF,
A little puff of smoke at throttle up is not a bad thing. It will likely clear up with more use. Using Marvel Mystery oil is a very slow way to break down sticky carbon on the piston rings and ring grooves. Your power will likely improve slightly as well.
Yes, adjust the valves would be the next thing to do. Adjust when cold. Pull the plugs so you can rotate the engine by hand using the top flywheel screen. Do one valve at a time while the adjacent one is fully open on the same cylinder.
Here is a video:
https://www.bing.com/videos/rivervi...8CD77450E24618145DD88CD77450E246&&FORM=VRDGAR
Also, check out a site called Teryl fixes all, he knows his stuff. He does dress funny and has some "creative skits" in most of his videos, but he knows his stuff when it comes to small engine equipment.
As for the Marvel oil, it does more good than harm to leave it is there for a while, then do a regular oil change before you park it for winter, or before you start it in the spring.
Air cooled engines are bad about carbon sticky rings, especially if the fuel sits too long.
ACF
well Auto Doc went out and checked the oil in the engine and it did not show any on dip stick, so added until got to lower mark on dip stick. started engine smoked like it did before, no need to adjust valves since it looks like will have to replace rings
Auto Doc's
Sorry to hear that.
Failed piston rings are not very common on this design from what I have seen over the years. Hopefully the cylinders are not scored badly.
There is a chance the heads have warped in the pushrod area near the cylinders. That was an issue on some due to repeated overheating
As this engine been run in dusty with the air cleaner off for any length of time?
EDIT: Don't overlook the breather valve located under a cover on top of the engine block. These have been known to fail the flutter valve and the gasket before.
Having 130 PSI compression just does not sound like failed rings. Scoring of the cylinder is still a possibility.
