The top ring is barrel faced, the second is tapered. The wider part of the taper goes up. The paint stripe should be to the right of the gap. The paint color is irrelevant.have new rings but the service manual i have says that the second ring should have a white stripe on it but the rings i got from Kawaski have a blue on one and other is pink so which is the top ring
The FR air filtration is fine for what is was designed for. Under the hood of a tractor or mowing grass not dirt. The problem is education on proper maintenance. Or buying the wrong mower for what it is being used for.FRs didn't have to best air filtration.
Pull your air filter off and check for excess dirt in the air intake.
