The Push mower
Here is the audio file: https://jumpshare.com/s/qi2QZkdC9OLszqa7q5iJ
Model: 44P777
Hours: 657
Engine is making a concerning noise and having a bit of trouble getting the engine to idle down. Best way to generate the noise is to let the governor run the engine up a bit then force the throttle lever up to touch the idle set screw then the sporadic/intermittent "clunking" will occur. I have attached an audio file where this "clunking" is present starting around 18 seconds. Note: when the idle kicks up a bit that is me allowing the governor to take over, then when the idle comes back down I am forcing the throttle lever to the idle set screw.
Thanks for any input.
Model: 44P777
Hours: 657
