Oil filter
ljb
Is there a trick or easy solution to removing the oil filter on a Kohler Courage 22 hp SV715 without oil going everywhere on frame and dripping on the main engine pulley? I put a bunch of paper towels behind and below the filter but it still released a lot more oil than I thought was inside it. And yes I drained the engine first 😁.
Hi ljb,
Pull the plug wires and crank the engine a few times while the drain plug is out, then let it sit and drain a little longer. Most oil filters have an anti-drain back valve made into them, so they are difficult to get emptied.
Next option would be to fashion a trough drain out of cardboard, then use a hammer and nail to punch a hole in the lowest area of the filter to drain it out.
Form A funnel is also an option:
Hi ljb,
Thanks Auto Doc for your help and tips. I will try this next time.
Never spill a drop of oil if the filter is loosened so it can be turned by hand , then a hole is drilled at 12 o'clock in the filter butt . Make a funnel that will fit under the filter that will touch the engine . Next rotate the filter ccw to 6 o'clock to put the drilled hole at the bottom and let er drain into a container .
That is a good idea, but many mower oil filters are barely accessible, much less drill a hole.
I like this idea. I will try this next time. Thanks
