Battery Terminals Cleaning
hlw49
Solution of baking soda and water will boil the crud out of the cable ends. Just stick the end of the cable in the solution.
Honest Abe
1756559806560.png is this the type of flat terminal you're referring too.....???
just use a brass brush, or some emery cloth...
Auto Doc's
That is a full-size side post automotive battery, I think he is referring to a half size top post lawn equipment battery like this: (Walmart)
Honest Abe
you're probably correct.... just thought I'd put that out there. (y)
