SeniorCitizen
There are battery cable / posts brushes available to clean the round connections . Is there a brush available to clean the flat terminals ?
Hello SC,Do those nylon , brass, stainless remove the lead oxide ? A regular steel brush like we have had available for all my life won't touch it . The hard surface must be removed so i use my pocket knife because i can't find my brush that has ben available for about a hundred years . When clean the lead and or copper must shine . Bet you know that .
That is only during charging - BUT - better safe than stupid. Agree, pull the battery out.Warning to anyone reading this reply: Remove the battery before attempting any soldering operations batteries will blow up due to hydrogen gas lingering inside them
What is a flat terminal? There are top post and side post versions far as I know........the flat terminals ?
I think he's referring to how the top posts aren't round like a carWhat is a flat terminal? There are top post and side post versions far as I know........
No wonder they call you SloMo
