No. Why add another point of failure? Fix what you have.If you’re suggestions of adding a small electric fuel pump is an option I will look into that.
For sure.First issue is finding out why there is no fuel coming from the tank. Possibly debris stuck in the pickup tube.
So the hose going TO the carb is plugged or highly unlikely the carb inlet port is plugged. Carb needle stuck closed?????Both vacuum and electric pumps not getting fuel to carb.
Either you didn't get to it yet or I was ignored. Holler when you do more testing.New carb. New fuel lines. New filter.
Engine runs fine if I continuously spray gas into carb from spray bottle.
slomo…Either you didn't get to it yet or I was ignored. Holler when you do more testing.
Use Stabil fuel stabilizer, year round. That way next season she starts like a new mower. Use it even during mowing season. Keeps your fuel fresh.I have a mid-90's Woods 6200 zero turn that has run fine since I bought it three years ago.
After sitting all winter, it refused to start this spring. I have pretty much run out of ideas as to what to check/replace next.
Fuel delivery issue and or dirty carb.it will only stay running if I continually spray gas into the carb.
All new parts, require, testing. No guaranty they will work. Especially from Scamazon or Fleabay. Chinese carbs are hit and miss at times. Best to clean your OEM carb first. Then go to China World slash Amazon and get a new carb.I installed a new carburetor, fuel pump, fuel filter and new fuel lines, including the hose from crankcase to fuel pump.
Clean and flush the fuel tank, like a new one. Compressed air and so on. Clean her out like a hospital.I primed the pump/filter/lines full of gas all the way to the carb but engine stalls out as it's not drawing fuel from tank.
Did you connect the hoses back the way you found them? Was this a new OEM pump or Scamazon? You need a solid fuel flow AT the carb inlet.and the fuel pump won't suck any gas from bottle either.
Remove the carb bowl screw or a drain screw if you have one. Remove the carb bowl. See if gas is coming out of the needle/seat. As in heading for the carb bowl but now the bowl is off.There is no fuel, other than in the gas tank. No matter what, the fuel is not evenbeing drawn into the the fuel pickup tube in gas tank.
What about the fuel tank? Dude, start pulling hoses until you can find some gasoline. Start at the tank outlet.......... Open the gas cap. Let it flow.Pickup, filter and all lines are not blocked or clogged in any way.
