Heads up on this one as the installation snap ring is wrong. Does not fit even if you open the ends enough. I am lucky to have saved the snap ring from 15 yrs ago that works. See image for comparison. The ears are too wide and don't fit even on diamond of the square hole, plus can't open it enough without twisting. Complainant already filed with Stens.
