Briggs blowing oil out crankcase vent
dana a
I made a log splitter back in the 1990's and it has an old 11HP Briggs with a 16HP V twin carb on it. I bought the engine without a carb and used what I had. It has run for years with no problems till today. The crankcase vent isn't attached to the card and when I finished splitting wood today I went to the back of the splitter and the ground was covered with oil. I shut it down and checked the oil level and none was showing on the dip stick. It was full when I started. What would cause it to suddenly start blowing oil out. I noticed the dip stick had been pushed up out of its tube also. It is held in with a tight rubber gromet.
sgkent
when it happens that fast to allow that kind of blowby to blow oil out , a broken ring, hole forming in piston, broken guide etc. All be catastrophic failures of some kind. That said, one cause can be that the breather has plugged and that only thing normal gases can do is blow out thru seals so do check the breather to be sure it is good. Also check the oil to be sure it is not full of water or gasoline. Foamy oil full of water or fuel reaching a temperature where the fluid boils off can push out oil too. I would start by cleaning it up, draining the oil left to look for contaminants, filling it with new oil and doing a compression test.
dana a
Thanks for the informative replies gentlemen. I have another engine I'll use till I get this one torn apart and fixed. It makes sense to me that you are probably right that it has a broken ring.
Forest#2
Head gasket blown
I suspect head gasket let go but ????????????
A engine model number, type and code would be helpful. (or even some pictures of the engine????)
Pull the spark plug and see if spark plug/plugs is loaded up with black carbon or oil. If so pull the head on that side and look at the head gasket if it's a twin. If a single head pull the head and inspect the head gasket if the plug is very oily or lots of carbon.
If you have a compression gauge you could check/compare compression on each cylinder, but a leak down test gives me more results.
Auto Doc's
I don't recall B&S making an 11HP twin cylinder engine. I'm still wondering how a "16HP carburetor" was mounted to this. The original description is a little confusing. The number on the engine cover are likely not correct. AKA Frankenstein build.
Did you get this fixed dana a?
dana a
Yesterday I topped off the oil and started it up and it ran fine and didn't puke any oil at all. The vent is a large hose about 1/2 inch and it has just a puff of air cycling out. I had a copper pipe stuck in the hose and routed to the carb. I found it laying out where the oil came out about a week ago from where the pressure blew it off. I took it back out to the log pile and split wood all afternoon and it never lost any oil. I have no idea why it did it that one time.
