GasSniffer
- Jul 17, 2013
- 250
So bad gas was the cause? Wow so ridiculous why manufacturers would think we even needed a oil pressure switch like this on a mower.
Doesn't Isopropyl contain 30% water?More than likely, the Ethanol fuel collected humidity which turned to water droplets in time. Seafoam is good for braking up the moisture droplets. A half bottle of rubbing alcohol would have worked also. Strange trick, but I have had it work many times. Isopropyl and Ethanol are not the same. Isopropyl will actually break up the water and allow it to get drawn in with the fuel.
How do you know? Something is causing your lack of fuel issue. Pull the hose off AT the carb inlet. Drain into a glass jar. Should have a gundy pulsing fuel flow if the pump is good. As in making a huge mess.All fuel lines are flexible - no internal hardening or degradation.
