Spindle failure
Davenj4f
Honestly, I would plug the bottom weep hole and put one in the top. With a weep hole at the bottom, it will never keep grease for very long once hot.
I like that thought. I will do next time I have them off. Or feel real industrious and not tired !! I hadn't thought of that, thanks.
I would say try a different grease. If it is sticky, once the grease is wiped away then you have zero lubrication. Sticky greases do not flow back into the area needing protection.
Mobile 1 is simply a lithium grease. Forget all the claims and hype synthetic this and that. They claim such and such base stocks.... Funny how they have several poor reviews on their own grease web site. Couple of them are yard/mower related.
Far as Lucas Red, already explained it. Nothing special what so ever. Super tacky that doesn't flow.
What I use is plain old school high temp disc brake bearing grease.
Davenj4f
I see a bunch on Amazon. Any particular brand to go for, or stay away from ? Or doesn't matter, long as it's hi temp disc brake bearing grease ?
I'm not a brand person. I have this one. I have the moly version of it that is black in color. More than enough for mower spindles.
MParr
Look at Valvoline's lineup of heavy duty grease. There are a couple that will do the job.
Davenj4f
Decided to go with
Schaeffer Green Extreme Pressure Waterproof Grease NLGI #2. Good for high temps also. Thanks for replies. Will check out all suggestions.​
Red Good
Is there a spacer on the shaft between the open sides of the bearings ?
SeniorCitizen
Yes. Notches at either end.
Those with a spacer between the 2 bearings , at minimum 1 of those 2 bearings needs to be a push fit . ie - the outer race needs to be able to be pushed in with your fingers .
Davenj4f
Not sure what you mean by pushing the outer race with fingers. I use my shop press to disassemble and reassemble. Attached is the spindle parts, nothing complicated.
