Here is a short video of this rake linkage rod that I think has too much play in it so basically the brake is off + I believe that rod should not slide the way it does even when the spring is attached it slides the same amount as if there's a way to stop that motion the spring itself seems to be a little bit too long I wonder what anybody knows about how to get rid of that play in that rod? Craftsman lt2000 2019.5 horsepower engine 42-in cutting width.
Thankks,
Jim
