steves snapper
- Apr 20, 2025
- Threads
- 5
- 24
no spark issue, inteck 12.5hp won't start
after adjusting valves and mowing 3 weeks ago,now no spark issue. she won't start. I double checked the valve adjustment an is fine.
checked w/ the el cheapo spark tester fits in-between spark plug wire an spark plug. didn't see an lighting but then it's mid day w/ direct sunlight.
I pulled the spark plug an as usale it's wet w/ fuel. swapped in brand new spark plug still no start.
I may have a spare coil from orginal engine how do I test this coil? thanks for advising
