no spark issue, inteck 12.5hp won't start
Removing the coils kill wire provided spark an she cranked up.
How long can I continue w/ this kill wire disconnected? Like is part of the coil failing?
thanks
It will run like normal with the kill wire off, but make sure you have a way to shut the engine down.
I cannot advise bypassing anything safety related. To truly resolve this problem, the key switch and all safety switches need to be checked. The wiring on these mowers is pretty simple.
This is a newer model Snapper than the one I have, so it likely has the little "magic" safety interlock box hidden near the battery area. A seat switch, a brake switch, a deck engage switch and even a deck chute safety switch are fairly normal on these
A few years ago I replaced the S terminal wire on key switchignition switch4 wire.jpg (blue wire)replaced w/ a grey run to S on new silinoid
Don’t remember seeing a safety switch next to silinoid.
Before that I replaced I think it was the brake safety switch it was located underneath near the clutch wheel.image
yester
yesterdays mow I just turned the fuel petcock off an ran her dry like I always do. I assume I could rig a switch from the black kill wire to ground for turn off. I'll inspeact the wireing that loose black wire looks a bit scketcky. will report back thanks
thanks
Ok now. You have a bad switch somewhere. Seat switch is 2 wires, jump across harness, try to start. if no start jump Brake switch same thing. If no start do same thing to reverse switch. If deck has mulch plug check switch. So if it starts being jumped replace that switch. Not the best way to check harness but easiest way.
A good diagnosis, I enjoyed all the responses as I have the same problem on a twin B&S L engine.
Interesting post, could a safety switch be killing the electric circuit and preventing the mower from starting. I will remember the tip about removing the kill wire.
If it is cranking but does not start because of lack of spark and you know the coil is ok, it most probably is your seat safety switch that is not working. (All the other safety switches would keep it from cranking).
No spark
Remove coil. Polish the coil mounting pads and coil where it sits on the pads. Coil needs a clean ground to make spark.
Still no spark, pull kill wire off. Engine should run the tank dry if coil is good. As in it won't shutoff unless you pull a plug wire off.
No spark with kill wire on, either bad wire or safety switch of some kind.
