LawnWizard
- Nov 17, 2021
- Threads
- 15
- 100
Good day all!
I am currently working on a Husqvarna YTH24V48 with Briggs Intek 724cc 24.0 hp.
Question is about the park brake switch. With brake pedal depressed it starts and runs perfectly. Blades engage with PTO. Issue is that as soon as brake is released, the engine dies. I ruled out seat switch b/c PTO should kill if seat not occupied. I have removed and tested brake switch. It has continuity as I would expect. (One pair with button out, the other pair with button depressed). With brake button in the engine runs perfectly (with and without PTO engaged. I believe the reverse switch would only effect the mower with the PTO on? Ignition switch? Ground issue? Any help greatly appreciated.
Hugh
Hugh
