Reline mower clutch
user4579
Good Day!! I was just wondering if anyone has found a place to buy the friction material to reline the mower clutch? we used to do this on the old dragline cranes and dump trucks. A new Warner (non China) one is about 300 bucks. So this is just a thought.
MParr
You can buy Ox and Xtreme clutches a little less than the Warner.
Auto Doc's
If this is a rider mower electric clutch, they do not have linings on the faces. They a magnetic pull in steel face clutch design like an A/C compressor on an older vehicle.
As they wear the air gap does get too wide for the coil magnet to pull in the drive plate.
user4579
Did not know that! I did assume that on a clutch there was a lining. Thanks for your knowledge!
