I have a mid-90's Woods 6200 zero turn that has run fine since I bought it three years ago.
After sitting all winter, it refused to start this spring. I have pretty much run out of ideas as to what to check/replace next.
Symptoms haven't changed from when I started troubleshooting and replacing parts two months ago,.
That is, it will only stay running if I continually spray gas into the carb.
I installed a new carburetor, fuel pump, fuel filter  and new fuel lines, including the hose from crankcase to fuel pump.
I primed the pump/filter/lines full of gas all the way to the carb but engine stalls out as it's not drawing fuel from tank.
I removed the fuel pickup from gas tank and tried drawing gas from a bottle while spraying gas into carb to keep motor running and the fuel pump won't suck any gas from bottle either.
I have tightened oil filter and oil fill cap to make sure vacuum/pressure from crankcase (if there) is preserved,
as it appears that maybe none is being created to suck fuel from tank and send it to the carb.
It seems the last thing to check would be to compression test the line from crankcase to fuel pump
but could that even be the issue if the motor runs fine when i feed it gas manually?
Engine is a Kohler Command V-twin with a Keihin 24 053 32 carburetor.
Any suggestions as to my next step would be much appreciated.
Thanks
