Eager 1 Craftsman 6.25 hp - Governor linkage inside bottom of tecumseh 143.026202 unknown.
MorrisWills
  • / Eager 1 Craftsman 6.25 hp - Governor linkage inside bottom of tecumseh 143.026202 unknown.
Dropped its oil after every session after parked for ten minutes. No leak atop it.
Flipped it and I took it apart from the bottom, observing that the oil seal looked good from that view. When I gently pulled the bottom section from the top, I felt a bit of resistance, which surprised me, and had thought mebbe there was a spring I didn't know about. The old gasket was indeed broken with a crack across the edge. It was thin black rubber, 1/64" thick. I had a sheet of 1/32" McCord gasket, so traced out a gasket and cleaned edges and all that and put it back together, but... there wasn't a gear connection for the governor to be in play. The oil pump was a sleeve that shot out from when the piston rotates, so I understand that and realize thet that shall keep the oil pumping around. I think mebbe had I removed the flywheel, I would have access to look inside the engine and mebbe see how a linkage wire is supposed to hook onto the governor, but mebbe that happened naturally when the two halves came together, 'cause I examined the thing and couldn't discern how that fit. Darned if I can get a good view of it with a parts' diagram, nor online websites. The rotary lawn mower 21" multi-cut model # is 944.362640 but the tecumseh engine model # is 143.026202.
Any advice much appreciated. Great website here. Thanks. M 14/06/25
MorrisWills
Thanks for the PartsTree link. I think I'll go into it from the top and try again. My browser kept stalling today, but it'd be a good idea to order the gasket pkg that's available. My mower is ancient.
Auto Doc's
Parts tree is a pretty good source, but make sure you have the correct model or spec number.
I will say at least many of the old ones still have parts available. Good luck with your project.
MorrisWills
Thanks for the support Auto
Docs
MorrisWills
Auto Doc's
What is the actual page number are you referring to? The image numbers are all different per chapter.
MorrisWills
To AutoDocs: The diagram #57 on page 77 is within chapter 9 "Internal Engine And
Cylinder" , the last topic there discussed "Engine Assembly". Our mower was bought at Sears. Diagram #55 shows a spring, though no such one was evident. The Cross reference chapter 10 does not list our engine, so for now, no help to find a muffler either.
