Toro Recycler sits Uneven/Wobbles when all wheels set to same height
Chuckers
  • / Toro Recycler sits Uneven/Wobbles when all wheels set to same height
My Aunt's Toro Recycler (20339) is sitting uneven on flat ground (checked on several different concrete slabs) even though all wheels are set to same height. It wobbles about a 1/2 inch. This wobble not only obviously makes it terrible to use but also results in an uneven cut.
- I thought no biggie, one of the wheel height adjustment mechanisms must be loose/damaged/bent or otherwise needs replaced. So I took each wheel off to check them, but this is not the case. All the wheel height mechanisms are absolutely fine.
- All the wheels sit straight (none are crooked or loose).
- The front drive axle isn't bent (but I already knew that because if it was the front wheels would not roll smoothly, but they do).
The only way to eliminate wobble is to adjust the height of either the front right wheel or left back wheel up one full notch, however this means the deck is uneven therefore you get an uneven cut (though it's not too too badly uneven a cut - but it bugs me lol).
I'm baffled. My conclusion is that the deck must've somehow got bent, but I have no idea how that could be (I'm the only one that uses this mower and it is never even transported so it wasn't dropped). There is no evidence on the deck that I can see that points to a bend, but it's the only explanation at this point.
I'm all out of troubleshooting ideas. Am I missing something else to troubleshoot?
NOTE: The image below is actually not my Aunt's mower, it is a pic from Reddit. I don't have time right now to go get a pic of my aunt's mower, but it depicts the exact same problem with her mower. I actually contacted that guy on Reddit and unfortunately he never found the issue and has since replaced the mower. It is literally the only page on the internet I can find that addresses this exact issue I'm having.
Just my opinion, but the deck in the picture shows a twisted deck.
Chuckers
I think you're right about that. My aunt's does not look like that. I hope to be able to get a pic in the next few days and post it. I see no bending/twisting on my aunt's mower's deck.
I was just hoping to get ideas on some things to check that I might not be thinking about.
Auto Doc's
Hi Chuckers,
A twist in a deck can be subtle.
Check the engine mount hole areas for cracking. The engine mounted firmly to the deck if the main stabilizing and strengthening component.
If the holes are cracking, this will induce metal fatigue and twist. The torque and vibration from the engine will consistently make it worse.
If that is the case... it's time for a new mower.
Throw a 4x4 or floor jack under the low side. Stand on the high wheel side. Bend it back. Those cheap mowers use very thin sheet metal.
Make sure you are on level surface.
As mentioned, check the engine mounting bolts.
nbpt100
That is actually an older Recycler. Not as cheap as they are today. I can tell by the Quantum Engine on it. It is at lease 11 years old. If the deck has cracks in it. you have a few options. Bend it back to the original shape as best you can. You can weld the cracks if you know someone who can do it for you inexpensively...... Or you can drill out the crack ends with ~ an 1/8 diameter drill. It will keep the crack from propagating. You can get some curved washers that AYP use to use on their engine bolts and see how it goes. You can also make your own. I have also used mending plates with nuts and bolts where a crack is long, to reinforce the area. As long as you are not being abusive I would bet it will last a long time and no need to trash it. We sometimes have too much of a throw away mentality now and react like that too quickly with out understanding what else can be reasonably done. That is a good mower with one of the best walk behind eninges used on a residential mower. It would be a shame to trash it with out 1st trying to resolve it. Good Luck.
Chuckers
Keep in mind that, as I said, the one in the pic is not my aunt's and is older than my aunt's. As stated, I only posted that pic for now as I cannot get to my aunt's mower and I wanted to use it to illustrate the issue.
Her deck is same but engine is the newer one. About 5-6 years old. Her model is 20339 if you want top look that up. Same mower, different engine than one in pic.
I hope to get a picture soon, though I don't think it would make a difference.
And yes, I would love to fix it if I can even find the issue. I have to take a much closer look.
Actually no. The 20339 she has is a piece of junk. It has manufacturer's defects from day one with the carb and the fuel tank, which is why I actually wish it would just give up the ghost lol.
I should have returned it the day I bought it for her, but I was too busy to worry about it. Not to be ride, but it's her loss, not really mine.
Last year I bought myself a Toro 21442 and it is much better. Does not have the tank and carb issues hers has.
