- Sep 7, 2024
- Threads
- 12
- 954
Hi digg7,
I think both of you are correct. The solenoid is intended to physically shut the fuel off, and it prevents backfires and run-ons While the engine is still spinning once the key is shut off. It also takes a lot of the reliance away from the fuel float valve as well. As fuel evaporates from the carburetor over time, the float needle relaxes. This can actually create a flooding condition where fuel can find its way into the cylinders and eventually into the crankcase oil.
In addition, the solenoid acts as a redundant backup safety in the event to coil kill wire fails to ground the ignition coil(s) properly.
For most of my riders I have elected to install an inline fuel shutoff and remove or clip off the stop plunger of the solenoid. I got fed up with them always sticking and having to be cleaned. High heat and fuel do not play well together here in South TX. Along with that I don't mow my grass (weeds) but a few times a year because it does not grow all that fast. My riders mostly spend time pulling carts for my grandkids to ride in.
