grumpyunk
 - Jul 13, 2015
- Threads
 - 0
 - 149
If you want to know if your fuel is adulterated with ethanol, pour some into a glass jar. Add a glug of water, say 1/8c into a peanut butter jar half full. If there is ETOH in the 'premium' fuel, it will be drawn from the mixture and combine with the water. It should then fall to the bottom of the jar. The fuel will likely look cloudy.I always use non ethanol gas. at least that is what it is labeled on the pump, sometimes I wonder if someone made a mistake... also use the stations with seperate hoses for each grade of fuel.
If you have E10, 10% max ETOH, you can make it close to E0 by adding water, allowing it to precipitate, and then decanting the remaining fuel which will not have any alcohol mixed. It will be of lower octane, but 99% of the air-cooled OPE won't care as they run lower compression ratios and will not ping. The de-mixed fuel should store better.
tom
