Husqvarna Z254F: No belt tensioner?
vangreenacres
I have 20 hours on a new Z254F mower. Last week the blades were slowing when I started to cut grass. I could not find a belt tensioner on the deck. Husqvarna Chat said there is no belt tensioner and that I had a stretched the belt. Stretched belt or not, is there no belt tensioner on this unit? I found an eye screw attached to a spring that goes to one of the pulleys; I monkeyed with that to no avail. Is it possible there really is no belt tensioner on this model?
Any help would be appreciated.
Apparently you got a hold of an idiot. Yes there is a belt tensioner on the deck. And you were adjusting the eye screw attach to the spring which attaches to the idler arm that auto tension the belt. Now that idler arm maybe binding up under the stationary idler pulley. If it is bound up no amount spring tension will overcome it.
As reference the deck belt is 1/2" wide x 152" outside circumference. So far I only find it in OEM 592951801 or Stens 266-313. So you can measure the belt to length.
vangreenacres
Thanks! I first tried, adjusting the Y screw to create greater tension on the spring, but to no avail. If anything, it seemed more loose. I’ll play with it some more. In the meantime, I bought another belt. I have had only two riding lawnmowers in my life. The first was another Husqvarna and it was great. if I could still get parts for it, I would! Thanks again.
Auto Doc's
That is trouble with chat sites. To many pretenders trying to get a pat on the back just for participation.
Item 21
Connect the spring by remove one of the upper safety covers to expose an outer blade pulley and slip the belt off, connect the spring and then walk to belt back on the outer pulley. You may have to pry the idler tensioner back a little to stretch the spring, but the belt will go back on.
jimvw57
If the pulley attached to the spring has a loose pivot point, the belt tension could be messed up. Pull the deck and see how everything looks.
liolondio
I have a Z254F too, and I had exactly this problem around the 15-20 hours. No tensioner visible, just this spring and this eyelet screw as you say. I changed the belt and it felt better, so she was clearly relaxed. Frankly, it's weird that there isn't a more reliable voltage system....
vangreenacres
I have a Z254F too, and I had exactly this problem around the 15-20 hours. No tensioner visible, just this spring and this eyelet screw as you say. I changed the belt and it felt better, so she was clearly relaxed. Frankly, it's weird that there isn't a more reliable voltage system…
I concur on all points you referred to. Ultimately, a new belt did the trick. Totally wish they had re-introduced the 2248Z again. Excellent belt tightener with just a flick of the lever. Hundreds of hours on my old one. I also had to replace the seat rubber bumpers with springs from my old 2248. Let’s keep in touch and see how things go.
