Jump starting an under-seat battery?
Elkins45
One of my mowers has the battery under the seat and has a safety switch that requires the seat to be down and depressed before it will start. With someone in the seat I can't see any way that a set of jumper cables would fit under there without running the very real risk of grounding the + cable. How does someone jump start a mower with the battery under the seat?
Stop it with all the bypass info please. Safety switches are there for a reason.
Having said that......... Tape the plunger down on the switch. Or a zip tie, something that will hold the plunger down.
This is for TESTING ONLY. Don't try to mow with it in this condition.
shurguywutt
So just bypass it mechanically instead of electrically :ROFLMAO:
Elkins45
Ever think about setting the parking brake, which bypasses the seat safety switch?
No, I didn't, but I will now. My only question would be if it bypasses the start circuit as well as the run circuit. It would be easy enough to find out.
Auto Doc's
Sounds like you need to pull the battery out and charge it and have it checked. The engine stator on a rider engine is not meant to "recharge" a battery, it is designed to maintain the battery and run the lights or the electric PTO for the deck if you have that option.
If the battery will not charge, replace it or will cost you much more trying to nurse it along by jumping it.
Never, bypass or rig any safety device. I have seen way too many injures and mishaps through the years. Accidents don't happen on purpose.
Set the parking brake and you should be able to jump it. Do not jump the rider with the vehicle running.
Don't know what rider this guy has but Kubota, Scag, Hustler, and Exmark are the brands that I have come across that require the seat switch to be activated to start the mower with the key.
Elkins45
It’s a Craftsman made by Husqvarna.
