One of my mowers has the battery under the seat and has a safety switch that requires the seat to be down and depressed before it will start. With someone in the seat I can't see any way that a set of jumper cables would fit under there without running the very real risk of grounding the + cable. How does someone jump start a mower with the battery under the seat?Jumper direct to the solinoid or battery under the hood.
Because the OP was this?Boy, has this thread taken a left turn, OP said he got his answer in post #7. Don’t know how we got on charging or jump starting a unit.
Bottom line, if @Elkins45 feels that the battery is suspect, then it's pretty easy to snatch it out and take it to a local auto parts store to test it. They can verify that it will or won't charge up, and load test it to make sure it isn't failing internally. Most do this for free in anticipation of selling a battery.One of my mowers has the battery under the seat and has a safety switch that requires the seat to be down and depressed before it will start. With someone in the seat I can't see any way that a set of jumper cables would fit under there without running the very real risk of grounding the + cable. How does someone jump start a mower with the battery under the seat?
