- Sep 24, 2017
- Threads
- 284
- 6,847
got a husqvarna 324L,4cycle, that apparently has a Honda engine, that is stumping me. Randomly dying, sometimes can save it with choke.. Fuel lines were about done for.
replaced fuel lines, filter, spark plug. Disassembled carburetor, it was spotless inside and everything is in good shape.
It may run for 4 or 5 minutes at full throttle and slowly lose RPM and die, no saving it.
It may also die if i tilt it the trimmer head up, engine down. Or it may stay running.
checked for air leaks around carburetor are and none present. Spark stays consistent, though i am using a glow tester and not one where it has to jump the gap.
problem seems to be more consistent once warm.
Oil level is good.
I'm going to inspect p&C next and check compression
I have not been able to find a published compression spec
This is my first time working on a 4 cycle trimmer so any help is appreciated.
Oil level is good.
