Adjusting valves Intek 12.5HP
I don’t see a lock screw inside the adjuster nut?
Machine Fastener Nut Household hardware Screw
I was expecting to see a allen or torque screw inside the set nut?
Engine Machine Automotive Fuel System Electrical cable Nut
Please advise how to adjust w/ just a adjuster an no lock screw?
thanks for advising
its in there...
what type allen or torque screw I have a set of each. thanks star tech
Torq head set screw. Just remember to set the clearance and then tighten the set screw. Don't set the clearence with the set screw and then tighten the adjuster nut. It will crack the nut in half.
