Model 734778 Drive Units Troubleshooting
Good points by StarTech. There was a number of problems with those Hustlers and the main one was the brackets holding the two hydo's together and in alignment was weak and the bolts and nuts loosened up and fell off.
There are two additional brackets that I installed on my Raptor SD54. Here is a picture with part numbers. I have had no more problems after installing these two braces. I also used Loctite as a backup but Hustler did go to Nylock nuts which were a big help.
The lower cross brace is massive compared to what came on mine from the factory.
You are a real ***; all you do is demean people. Nuisance to the whole community. I would love to see you work in my shop for a couple weeks just to see how stupid you are. Probably takes you a full day to diag a spark plug. Go away; Blocked and reported. You must be one lonely person.
Chill man, "if you can't stand the heat"....., well 🫣
Nice fabrication... I appreciate the hel
