Too Much Oil?
Lbbdoc
I checked several sources and they say my Craftsman T2200 riding lawnmower with the Briggs engine should hold 1.7 liters of oil, which is over 50 oz. I checked the dipstick after adding 36 oz. and it was way overfilled. Do some of the engines take less oil?
dougand3
Briggs model #? Stamped in a valve cover or shroud.
Lbbdoc
There are numbers everywhere! Not sure what is what but will try to get something this evening. I did find a sticker with the oil capacity listed as 48 oz. I put 36 oz in and it was all the way up to the very top of the dipstick. I had to let some out to get it within range.
Skippydiesel
First check that you have the correct dipstick for your engine:
With most vertical shaft B&S engines, you can check the dipstick for correct length & Min/Max markings .
Just hold the dip stick vertical on the outside of the holder/tube, cap at the lock/screw down position, the Max mark should pretty well be level with the join between upper & lower crankcase :devilish:
Lbbdoc
There are some shrouds I will have to remove to check that out when I get a chance. Meanwhile, I found these numbers - MODEL 33R877 - TYPE 0002 G1.
Craftsman Garage
The spec is 48oz. Did you change the oil filter too? Just run it for a few minutes to let the oil fill up the filter and oil passages, etc. Are you on any kind of incline?
