Skippydiesel
- Nov 29, 2020
- Threads
- 13
- 258
Spindle bushings - ? The only spindles I know of are the cutter deck spindles (x3) with bearings not bushes.First question I have is, are the tires correct? Don't pay attention to the numbers on the sidewall, measure the actual height with correct air pressure. It's a crap shoot if tires a mismatched.
Spindle bushings are a common wear item, and they will make the frontend appear to be "twisted".
There are bushes in the front wheel rims - they are all good. Front axle is level with the ground.
This is likly a terminological misunderstanding - please go further with your description
Tyres are matched across the axles
