Bent Chassis?
Skippydiesel
First question I have is, are the tires correct? Don't pay attention to the numbers on the sidewall, measure the actual height with correct air pressure. It's a crap shoot if tires a mismatched.
Spindle bushings are a common wear item, and they will make the frontend appear to be "twisted".
Spindle bushings - ? The only spindles I know of are the cutter deck spindles (x3) with bearings not bushes.
There are bushes in the front wheel rims - they are all good. Front axle is level with the ground.
This is likly a terminological misunderstanding - please go further with your description
Tyres are matched across the axles :devilish:
kbowley
What model is it...such as 264-H, 430-gt, just the model on the hood or steering tower? They made plastic hood models going back to the late '90s. To be sure it is the frame, measure the distance from the floor to the frame at the front axle on both sides. Sometimes it can be the hood mounts causing it to appear twisted. Another measurement would be the space from the top of the front axle to the frame where it articulates. Those frames did have a lot of flex...try driving it into a step gully, such as a drainage ditch, at a 45-degree angle, and you will see what I mean. It will flex a lot before lifting a wheel. The weak spot is between the rear of the engine and the steering tower.
They also called the part that front wheels are mounted on spindles which can be to the front axle by bearings or bushings. Depending if the mower is a riding type or ZTR as to they look like.
Here is an example of a front spindle from JD.
Now the assembly that this attaches to they call the axle that goes from the left to right side spindles that pivots in the middle.
In the case of the D150 the cast iron axle has no bushings from the factory but a resourceful mechanic can add them. Other mower can bushings like the Gravely ZTR I did back a couple months ago that nylon bushings in the axle which both side were busted.
Skippydiesel
This is a Toro Wheel Horse 17.44 HXL - I apologise for not giving the full details at the start.
Still cutting a great lawn. Still looking a bit "wonky" from the front - wife (main user) loves it :devilish:
kbowley
Ah, very weak frames and a common issue...run er. Surprised the hood is still intact!
Skippydiesel
Who said the "hood is still intact" - It sort of is - I have replaced the front with sheat metal, riveted on and the broken plastic top vent with an aluminium one. Toro goes a lot faster now :devilish:
sgkent
so maybe the sheet metal is crooked :)
Skippydiesel
HaHa!
I may be an amature sheet metal worker but no the problem is elsewhere. If I take the bonnet/hood off the engine looks crooked.
As the mower is working well I don't realy want to disassemble the whole thing just to fix what is an aesthetic annoyance.
I wish I could post photos on this Forum, you would see for yourself.
Out of several forums that I contribute to, this is one of two that wont accept photos, from me? Australia? :devilish:
Skippydiesel
"Ah, very weak frames and a common issue...run er"
By "runer", do you mean chassis rails?:devilish:
