Givey1982
- Feb 24, 2025
- 3
I need a new carburetor for my 2006 Toro SR. My issue is that my SR (6.75hp B&S) has an oval air filter on the right side of the motor. None of the carbs I have bought (used part number from book) have a primer hole that lines up with the air filter adapter which is where the primer bulb is located.
Has anyone else seen this? Any options? The mower will run is I use starter fluid but it won’t prime and start
Here is the adapter on the mower
