outdoorpowermike
Yes, test battery under load. If test low charge and retest. If still low voltage at battery replace it with correct battery. Now you still might still get a click sound but you know you have a good battery. Check for good clean grounds. If still clicks you have a broken wire harness end not making a good connection. All most all the wire ends in the plastic holders have brass ends that have a slightly bent connecting spot that makes a tight connection against the male post, this is where it has a poor connection and will always chick. Check ignition switch plug first. Look carefully at the tip of the brass ends and you might find the problem.
