Welcome to the Exmark Forum -- Check in Here First!
heloduby10
  • / Welcome to the Exmark Forum -- Check in Here First!
Recently purchased a exmark lazer z e series, 60” deck with the Kawasaki engine. Seems to be a good mower however there does appear to be a manufactures defect concerning the right hand motion control lever. The lever is prohibited from going full forward due to the spring-leaf hitting the control lever frame box. The dealer made adjustments so the mower would track correctly however now the mower will not operate at full power.
chilipeppermaniac
Hi,
New to forum due to new to me Exmark Commercial 48 inch Walk Behind. Best I can tell, it is somewhere in the 1994-1996 vintage. Not able to readily find the serial number but model number appears to be a M48 K12.5-K5 with the Kawasaki 12.5 hp motor
Will be seeking parts and mechanicals help with questions.
Not sure if I will post here or in more specific place, Likely the latter.
bald mark
Hey Everyone,
My name is Mark, I have a 2007 eXmark Lazor Z CT 48”, Briggs and Stratton Vanguard 18-Twin with 716 hours on it. I bought it used a few years ago with about 220 hours. It has been fine till this past season. I had to replace the sump gasket and replaced the main seal while it was apart. Also, drive vibrations I will describe in another post. Happy to have found this forum.
GREETINGS to all Exmark mower owners!
If you're new to the forum, please reply to this thread and introduce yourself and your mower (that is, if your mower have a name). Maybe attach a photo or two of your mower and show off your pride and joy.
Also, if you haven't done so already, you can upload a user avatar (picture under your user name). You can do so by clicking on settings and "edit avatar" or just click here.
Please be helpful and friendly to all other Exmark owners (how could you not, right?) and if you like this forum, tell your friends about it.
We want to make this the best resource for Exmark mower owners, and to do that we need your help! Questions? Experiences? Stories? Data? Photos? Articles? Links? Cool Exmark stuff? Post it here!
Last but not least, please let me know if you have any suggestions for the site. We'd love to hear them.
Just Joined the forum, and I own a 2004 Exmark Lazer Z 48" that I just bought last year. I'm no newbie to mechanics, repairs, and overhauls however, I have no prior experience with an Exmark mower.
BradK
My name is Brad and I'm in the Cleveland, OH area. Replacing a 13 yr old Cub Cadet ZT with an exMark to cut my 2 acre yard. Between the Quest X and Radius E. See my post below....Any suggestions welcomed.
MParr
Of those two, the Radius E.
Shop other brands with similar features. Often times, you can get more from other makers for the same money.
k6fn
hello, im jerry and have a great Lazer model. it had provided 8 years of great service and continues to perform great.. my issue now is the starting is hard, it cranks a long time before it starts but runs great after that. my suspect is possible a bad hose on the vacuum fuel pump system. The choke operates fine too. so wonder if anyone has advice other than to check/replace the hoses??
thanks in advance
