Simpson doesn't give me any issues as far as warranty. The issue I run into is getting Gardner to process the claim and issue the credit on the account without emailing the warranty department and basically say you are not doing your job. Simpson gave me fits this past summer on one of the pressure washers with a CAT pump. Now CAT pumps have to be shipped back to CAT at owner expense for warranty consideration. But after requesting the RNA, CAT approved the pump, and shipped me a new pump and then FNA paid for the warranty plus the return freight.Yes some a royal pain to deal with which is one reason I am a n independent shop. Most OEMs are basically terrible after the sale. If you read the warranties they basically have no responsibility except to replace defective items on the equipment. Even then they will fight you every inch of the way at times.
Just recently had to personally warranty a pressure washer pump with a Simpson pump. Simpson flat refuse to honor their warranty as the they had recently stop manufacturing the pump. Three month into the one year warranty. I found that they had installed a bad piston which took out all the seals including the crankcase seal. I had to eat about $170 in repair parts on a $200 pump. That will be the last Simpson pressure washer pump I buy and sell.
And BTW the local authorize Simpson repair shops had refused to even take the pump in because Simpson refused to pay for warranty that they had already had done.
The thing with Simpson/FNA is there is a $0 warranty approval, so everything has to be factory approved prior to warranty repair. Pumps are not repaired the are replaced with a pump shipped from FNA in Mount Prospect, IL and then the old pump is shipped back using the return tag supplied in the box that was shipped to you with the replacement pump. FNA supplies the dealer with a reference number that is basically your approval to file the warranty claim with Gardner. I probably file 1-2 claims a month during the summer and a few scattered throughout the slower months.
The biggest issue I see with pressure washers is frozen pumps after the winter. Most will show up at the shop from late March to early May when they get them out of the garage for the first time, and then they have a water leak.
