Please help me find this part!
marcshaddix
Alright you guys, I have searched forever for this one simple part. I don't know why it's so impossible to find, but it seems to be. I have a Cub Cadet XT1 Enduro 50", and it has been mostly a <fkn> lemon since I've had it (about 9 years?). ANYWAY, I had a hose rot and the mower wouldn't run anymore. So the hose runs to the top of the gas tank, and then into the air filter area. Without it, the engine will run for a bit but then sputter out. My searches have suggested that it's an EPA EVAP hose, but I have been unable to confirm, and unable to find one for purchase. I found what Kohler showed was the part, and the part number, but nobody sold it, and I had to go to China to finally find one. When it eventually came in, it was like 5 inches long. This thing is supposed to be like 4 feet! Can someone PLEASE shed some light on this?! I really need to cut my grass.
marcshaddix
Sorry if this is way too much, but:
Engine Brand Kohler®
Engine Model 7000 Series
Engine Model Number KT735
Engine Displacement 725cc
Engine Output 24HP
Starter Type Electric
Fuel Tank Capacity 3.0 gal. US (11.36 L)
Cylinders Twin
Engine Start Ignition Key
Engine Oil Capacity 2.0 qt. US (1.89 L)
Lubrication Fully pressurized
Charging System 12 amp regulated
Fuel Gauge No
Governor Mechanical
Choke Separate Choke
Air Filter Dual element
Oil Filter Yes
Fuel Delivery Carburetor
Battery
Battery 210 CCA
Battery Type AGM (Absorbent Glass Mat)
Battery Voltage 12V
Drive System
Transmission Tuff Torq® K46
Forward Speed 5.5 MPH / 8.6 km/h
Reverse Speed 3 MPH / 4.8 km/h
Rear Axle 3/4"
Drive System Hydrostatic
Transmission Control Foot Pedal
Transmission Housing Aluminum
Rear Differential Lock No
Cutting Deck
Deck Cutting Width 50 in
Deck Wash Yes
Deck Material 11-gauge steel
Deck Engagement (PTO) Electric
Deck Construction Fabricated
Blade(s) Three
Deck Lift Manual
Cutting Height Range 1" - 4"
Anti-Scalping Four gauge wheels plus roller
Deck Positions 12
Chassis
Frame Robotically welded
Turning Radius 16"
Bumper No
Rear Tow Hitch Yes
Corrosion Protection Yes
Front Pivot Bar Cast iron
Controls
Cruise Control Yes
Brakes Disc
Comfort
Seat Type 15" high-back
Armrests No
Seat Adjustment Lever
Floor Mats Rubber
Wheels
Bearing Type Poly Bushing
Rear Tires 20"x 8"-8"
Front Tires 15"x 6"-6"
Tire Tread Turf Saver
Specifications
Series XT1® Enduro Series™
Additional Specifications
Hour Meter Available Separately
Mulch Kit Available Separately
Headlight(s) Dual-LED
Cup Holder Yes
Operator Presence System Yes
Model Number 13AQA1TLA10
I hope I picked the correct model number since I am just guessing which one of the 5 models of mower you may have.
Item 1 is part number 751-12089-51 or 751-12089-45 depending on length
marcshaddix
The only one i could find was part no.
24-326-143-S​
Your photo seems way more accurate
The thing about lawnmowers is the engine, transmission and the mower itself are considered 3 different products as far as parts lookup . So what you posted is the part number for the vent line that comes with the engine from the factory. The part from the engine to the tank would be considered a MTD Cub Cadet part,
I'm coming up with 751-12089-34 for the 13AQA1TLA10 model (all four years). This is a 3/16 ID by 34 inches length hose. Can be a simple rubber vacuum line hose or a braid fuel line hose. The vacuum hose is not meant for handling raw fuel but works fine as a vent line. Your local auto parts dealer should have it.
BTW the PNs IL post are also valid as they are 51 and 45 inch length 3/16 hoses.
Personally I stock both types here in bulk lengths as I worked on kids ATV until late this year. But a couple ripoff customers has caused me to quit servicing them. They can now go to the higher priced shops.
marcshaddix
If you say it’s the right part and can ship it to me, I’ll be on that. Email me marcshaddix@gmail.com
I don't do sales other than locally as it is now a paperwork nightmare with double taxation.
