Tpieman22
- Apr 19, 2022
- Threads
- 4
- 12
Changed carbs adjusted valves still the same thing hunts real bad only runs with choke half on. Changed carb head gasket and lapped the babes still hunts an dies without choke on
YesHave you reset the governor?
I changed the governor when changing the camshaft.
The surging has been going on for couple of years. The new carb did not help either new head gasket too of courseI changed the governor when changing the camshaft.
Runs fine with two fingers on the air intake or the choke about half on.The surging has been going on for couple of years. The new carb did not help either new head gasket too of course
yeah valves did not have any cuts blued them had contact"Lapped the babes", huh?![]()
I’m not their now it is on a red craftsmen 42” cutEngine model no. ?
Model 33R877 type 0002 code 140757Engine model no. ?
