Homemade oil extractor
chobbs1957
Question concerning oil-fluid extractors:
I see several on YouTube that either use a home-made or commercial vacuum extractor for pulling oil up through a small engine oil fill tube, works pretty well. Some are powered by an air compressor, and I’ve seen home-made units use a shop-vac.
My question is why not use a fuel-oil electric pump? I could wire one of those up with alligator connectors and plumb it with some ice maker tubing…. I think I’d spend about $35 instead of $90-$150 for a bought unit and less complicated than a $40-$60 homemade unit.
Got one off Scamazon for 25 bucks. Has 12v battery leads on it for power. Nice long tube to extract used oil.
GrumpyCat
How do you prime it? The store-bought extractors suck oil out, starting with a hose full of air.
Some automobile dip stick tubes are routed to the very bottom of the crankcase pan to facilitate oil extraction. Mercedes-Benz is one I have direct experience with. The large Harbor Freight oil extractor with big steel tank has a hose fitting which exactly fits in place of a Mercedes-Benz dipstick.
On the other hand Ford put a baffle and other obstructions in my 2018 F-150's 2.7EB dipstick. Absolutely can not use an oil extractor on that engine, not on the dipstick tube, not with a tube inserted in the dipstick tube.
Tiger Small Engine
Or buy a Mityvac oil/gas extractor ($100) that you pump by hand, holds about 3 gallons, and will last a long time because it is a well built unit.
They self prime. Mine works great. I feel lazy as to not having to crawl under the car and dump oil all over the garage floor LOL. Kinda like cheating on an oil service.
