kevinfromwebb
- Oct 10, 2024
- 5
I've got a hrx2175vka mower. I had trouble starting it so I cleaned out the main jet and then it would start for a minute and surge rpm. I cleaned out the idle jet and now it starts but at a very high rpm. Above the screw that covers the idle jet is an adjustment screw with spring around it. I had to remove it to get to the idle jet. Would this be the cause of the high rpm and how should it be adjusted?
Thanks for any help...
