SeniorCitizen
- Aug 28, 2010
- Threads
- 142
- 2,287
Would anyone know where the rectifier is located on a John Deere LA135 LE ?
Thanks XP. I've had the shroud off a few times and didn't remember seeing it but if I get time in my busy schedule (retired :biggrinIt should be bolted to the black engine shroud with a few wires coming out the bottom. Hard to miss if you have seen a small engine regulator before.
Ok and thanks xp.Sorry, I just looked at one at work and I was wrong. It is a small square box bolted to the steel shroud behind the left cylinder head sitting in the seat, above the oil filter. One bolt going through the middle and a yellow and red wire coming out of it.
