mpqualdie
- Sep 19, 2020
- Threads
- 1
- 11
The compression release on your camshaft is broken so it won't release the compression, not allowing it to spin past the compression stroke. It's an easy fix if your mechanically adept. Remove the motor, drain the oil, flip it over and remove the bottom, change the camshaft and lower seal (on the removed engine bottom) and then put it back together. Adjust the valve rockers. Take painstaking time to ensure all of the shrapnel from the broken compression release is cleaned out of the motor. Take your time to clean the crankshaft and put the bottom back on as well or the seal will leak when done.I am a self-employed lawn mower repairman, and have been repairing small engine equipment for many years. I am currently working on a Craftsman T130 that is causing me major grief! Following is the issue with the mower, along with parts I have replaced:
When I try to start the engine, it tries to start, but will NOT spin completely over. It acts like the engine is locked up, but engine is NOT locked up. Then the starter gets warm/hot along with the cable end at starter.
I am next going to check the forward-neutral-reverse switch and plunger on the rear-end for shifting rod.
I have replaced the following parts:
1) two new belts 5) new positive battery cable terminal
2) two new safety switches (brake and blade engaged) 6) new starter
3) fixed park brake with new "park index control" 7) charged battery
4) New solenoid
ALL TIPS WILL BE GREATLY APPRECIATED!!
