Briggs knocking and low on power.
hlw49
Community Leader
Location
Tennessee
Briggs 104M02-0005-F1 engine on a Snapper walk behind 12AVB2A2707 SER 1K195K31260. Customer brought it in and said it sounds like it is knocking and low on power. Sounds like the knock sound is coming from the carb. Any idea what it might be.
Since OHV probably not a bad idea to check valve clearances. Also if the flywheel key is partially sheared and firing at the wrong time could be popping back out the intake into the carb.
Checked both not the problem.
If it were me, I would take everything apart down to the piston head to see if somethings got in there, and the piston is crushing it. If not, it could be something loose like the carb I would guess since it's low on power.
Would not go that far but some detritus in the cylinder can do that like one of the screws from the choke / throttle butterfly
Same story with the cooling fan so worth while slipping the blower housing off and run it for a minute or so see what happens .
