oldntired55
so, does anyone know the measurement specs on counterweight groove, and the rib it rides on??? i have .005 clearance... when i move it side to side it 'knocks'
I do not have any specs. I seen the same thing on my knocking briggs. (counterbalance raised groove surface weat at the sump end)so, does anyone know the measurement specs on counterweight groove, and the rib it rides on??? i have .005 clearance... when i move it side to side it 'knocks'
yesterday i was between jobs in my shop, i remembered quite a few times using a centerpunch to raise metal for a closer fit.so i put several marks on the edges of the sump. where the weight rides... the counterweight fits alot more snug on the sump. i know it will not be a permanent solution, was just trying to make it tighter. i may do the same inside the counterweight links, as they are at their size limit... so i really cant be sure where the 'knock" was... but im thinking it was the weight rattling... it was quite noticeable.. more laterI do not have any specs. I seen the same thing on my knocking briggs. (counterbalance raised groove surface weat at the sump end)
What you mention is what I also seen on my engine that I mention in post #6 and 9. I could see some wear on the counterweight raised groove on the sump. I installed a counterweight from another engine that had bad crank My engine had .030 crankshaft end play using the sump gasket. I shimmed the crankshaft at the sump end to reduce the end play to .005. It slightly changed the tone of the knock.
I'm thinking I should have shimmed the flywheel end of the crankshaft so as to reduce the counterweight clearance at the sump end at the raised groove.
I just set the engine back for maybe sometime later. I thought about just removing the counterbalance and trying the engine at low idle and see if it still knocked or maybe another sump from a salvage engine. I could also see where the counterbalance has been banging on the raised aluminum groove. I just recently had a donor engine come to me non-running so I now maybe have some donor parts to try and take two and make one or have parts to sub.
It will be few months or cooler weather before I get back into this one.
Keep us informed as the what you try?
another thought, i wonder, with all the yrs Briggs has been using plastic internal parts... couldn't they have designed a replaceable nylon sleeve for the counterweight??yesterday i was between jobs in my shop, i remembered quite a few times using a centerpunch to raise metal for a closer fit.so i put several marks on the edges of the sump. where the weight rides... the counterweight fits alot more snug on the sump. i know it will not be a permanent solution, was just trying to make it tighter. i may do the same inside the counterweight links, as they are at their size limit... so i really cant be sure where the 'knock" was... but im thinking it was the weight rattling... it was quite noticeable.. more later
i need to go measure the sump guide again..im thinking it was on the .248 side..The unworn sump guide is .248-.250". Don't have the counter weight currently available to measure the groove.
no it does not...but tksI have seen worn electric PTO clutches produce a knock at low RPM.... if this has an electric PTO
You asked: Has anyone tried running one of these engines WITHOUT the counterweight inside???Has anyone tried running one of these engines WITHOUT the counterweight inside??? ready to experiment...i recently acquired another engine, this one a 20hp... same noise...
